Coupe rear side windows
Straightpipes
I'm about to start looking for a rear side window for my 41 business coupe. Are all the rear side windows the same size up to 48? Is the business coupe different than the 5 pass coupe? Thanks, Butch
Butch,
I have a '41 Sedan coupe with a rear window out. I would measure it or the opening if that would help you. These widows swing open.
Regards,
Dick
I only have a body book that describes the 46 through 48 models. I think the business coupe was the short body type model 77 or 5 window coupe for 46/48.
Both have similar shapes but the part numbers are different. The 46/47 model 72 sedan coupe had P/N beginning 19A which would indicate a 41 Mercury prefix and the model 77 5-window version has a prefix 11A which would indicate a 41 Ford car prefix.
If yours is a model 77 coupe the 46/48 parts may work but trim components may be different.
Kerby
Butch,
1941-48 Business coupe rear Quarter windows are all the same.Sedan coupe is different. I have new glass if you need it.
Thanks,
Todd
