What you have is commonly called a 'c' crank. Calling them that may be incorrect but everyone knows what that is and it saves time explaining it. In the old days most people just turned the C crank down to A size, B rods must be used. I recently did what you are asking about and turned the crank half way between A & B size, I then had the block babbitted but if I were to do it again I would turn to 1.800" and use Corvair inserts, other bearings may be available at that size too??? The mains on the A are 2" between bolts, 1.800" leaves enough room for inserts without hitting the bolts when line boring. Have fun!
