I get alot of parts covered with cosmoline. You can spend a day with parts clearners. Two ways to remove it. Real hot water will melt it. But this is what I usually do. I fire up my space heater, have a container of parts cleaner handy, hole the item with the cosmoline on it with a pair of channel locks in front of the burner from the space heater, the wax will melt right off, then slosh it around in the parts cleaner and it will be just like new. I can do a set of piston or bearings in no time. Just dont hold the item in front of the burner long enough to melt the part. Walt
