corrosion on voltage reg.
IVT1
What causes corrosion at the hot wire & terminal on the voltage reg.?
'41 ford 6 volt that is hot wire from the batt.
Thanks
Worry about poor ground. Run a ground wire from baseplate of reg to battery ground cable end, another to generator directly. I think but am not sure that '41 gen will have a stud for the ground wire...that was added to the circuit about his year, but not sure of exact time.
A bad connection between the terminal and the wire can cause heat damage that can look like corrosion, if the screw is rusty it can also be part of the bad connection.
When I fix a connection problem in a terminal I cut back to good wire, and either splice in a pigtail, or crimp and solder a new end on depending on how far I have to go in the search for undamaged wire.
A previous repair with acid core solder can cause corrosion in wires, you need to use rosin core solder on wires.
