Correct Tire Pump - 1929
bobgreco
I found a tire pump at a local sale, but I am not sure what the correct pump for a 1929 Model A looks like. Does anyone have any photo's they could share, particularly of the base?
Thans a bunch!
Bob
Does this help?David Adair is the Tool Guru of Model A's! can save pic to your comp and hopefully enlarge.
Don, was there a variant made by another supplier? The reason I ask is that after 1931 ('32 up style very similar to A, different location of hose outlet) there were generally two suppliers, one using the screw-on cup top as shown, the other with a tin cap showing a nut-like stamping that crimped over a flange...has to be finessed a bit to rotate the cap off the flange. On these all dimensions and the location of hose outlet are identical other than said top.
