I just went through this and this is what i did and so far it has worked. I bought the 17 tooth gear from Brattons and a turtle from Macks. It had no markings on it but was assured it would work. Surprise it didn't. It promptly ate up the gear. I got a new gear installed it in turtle put grease on both the turtle gear and drive shaft gear took transmission out of gear,spun a rear wheel and took the turtle off to see how they meshed. Then i found some metal pipe of the same OD as the drive shaft, wraped it around the pipe with sandpaper and proceded to sand the turtle. After some time i was able to bring the gear down to make a good match and the turtle retained its original shape.
