Correct carb for 33-34 pickup
Given the two you list, I assume that you are referring to the carburetor on a four-cylinder engine. If that's the case, it was a Zenith.
Also note it is not the same Zenith used on the Model A. It has an easy to see rectangular shaped float bowl while the float bowl on a Model A is round. Compare the gaskets in the vendor catalogs if you don't understand what I mean.
Charlie Stephens
