What I found that works best for me when installing the cork type gasket, is to leave the gasket in one piece. Bolt the cover halves together (not on the torque tube) and test fit the gasket into the bottom half first, then bring the ends together into the top half, with ends of gasket butting together at the top of top half. Some gasket trimming on the ends will usually be required. When installing the cover halves in place behind the transmission, put the one piece gasket in place in the bottom half as previously described and put it in place with nuts installed hand tight. Then put the top half in place while carefully feeding the ends of the gasket into the mounting groove. Carefully bolt the top half in place. By using this method you will have a continuous gasket with ends butting together in the top half of the cover. I use a light coating of grease on the inside surface of the cover halves as well as the cork gasket. This helps everything slide in place. I don't know how this would work on the Roy Nacewicz felt gasket or Hot Rod John's rubber tubing gasket.
