Ray A from PA
After installing a temperature gauge with drilled water outlet to my cooling system that has a 160 degree thermostat and setting the anti-freeze to -25. The gauge reads 190 degrees or right on the danger range after driving warm up. Prior to installation, there was a small seep at bottom of radiator that was corrected by a small can of Bars Stop Leak.
Do all indications point to a possible new radiator? Do the heavy duty radiators with 8 fins per inch and 95 tubes fit well as a replacement?
