skip
The 'A' cooling system holds three U.S. Gallons.
If you can not cool it with two and a half U.S. Gallons, your not going to cool it with three U.S. Gallons.
Some common sense needs to be injected here. The cooling system is a 3 gallon affair. No more than 2-1/2 gallons is needed to circulate around to cool the engine if the radiator is free flowing and grease free and has tight fins to tube contact. Were talking a 1930 unit. Were talking mine. I did make a water dip stick for peace of mind. Hot or cold I know where my level is. I don't use a restricting thermostat and I don't overheat if the timing is right. That's a whole nother ball of wax.
Any more water than 2-1/2 gallons up to engine temperature in this non pressurized system tends to puke out the overflow tube or out the top of the radiator. And an overflow bottle does little good and has generally been not needed for 80 plus years, millions of 'A's and billions of miles. But I could be wrong.
skip.
skip.
