My 28 aa ar has a problem with coolant loss. I fill it up and after about 30 miles it starts to overheat from no coolant. I suspect the waterpump is over working. It is a restored original radiator and a rebuilt motor. What would you recommend for it? Would a thermostat slow that Dow ?
Many possibilities, but we can say for sure that if you're overheating "from no coolant", it's not going to seek it's own level; something's wrong, and I seriously doubt if adding a thermostat is going to fix it--new Model A did not need one to avoid overheating.
One question is, which comes first: coolant loss or overheating?
The latter could be due to too-tight new motor (as suggested), retarded timing, dragging brakes, and probably many more things. Once overheating has happened once, the head can be warped, the gasket will then leak and/or blow, compression/combustion gases will then leak into the coolant system and further overheat and blow out the coolant, which will then cause terminal overheating. OR, the head and motor deck may not have been milled flat and the gasket not properly torqued down and sealed, so leaking compression would blow out the coolant without preliminary overheating. If leaking head gasket is the culprit, it often will show up as explosive coolant loss under load. NAPA sells a "block tester" to check for combustion gases in the coolant (be sure to buy also the "large motor" adapter to fit the Model A radiator filler opening).
OR, the radiator or somewhere in the block's coolant flow path is blocked. Did the "restoration" of the radiator include rodding out the tubes, and did the rebuilding of the motor include cleaning out the coolant path? If not, repair PROPERLY or replace. In my case, the motor rebuilder left a shop rag in the head!! Also, a repro radiator had too small of a hole cut out where the lower tank connected to the radiator outlet.
A quickie check for extremely blocked tubes is to run the flat palm of your hand across the front of the radiator: temperature should feel uniform horizontally and go from hot to not-so-hot from top to bottom (you can also use an IR temperature "gun"). Totally plugged tubes will be strangely cool from top to bottom, but this test may fail for partially plugged tubes. You would never expect the radiator of a modern car to last for 80-some years--just replace the thing and be done with it. Then, resolve not to plug it up again right away by pumping waterproof grease into it through the water pump grease fittings.
