W WHMCJM@SBCGLOBAL.NET Junior Member Sep 10, 2021 #1 How do i monitor the coolant level and when it's low what is too low?
1crosscut Well-known member Sep 10, 2021 #2 As long as the coolant is over the top of the tubes in the radiator you are good to go. No need to add any coolant unless they are exposed. Too much coolant and it will push the excess out. Resist the urge to put any in unless the tubes are exposed.
Jacksonlll Well-known member Sep 11, 2021 #3 You should not have to add coolant very often. If it keeps going away, you have a problem.
B Big hammer Well-known member Sep 11, 2021 #4 Fill it above the baffle, open the drain on the lower pipe, close the drain when the coolant disappears
