PeterBo
I have just changed the engine oil - No problems.
I was emptying the drain pan into a drum for responsible disposal when at the bottom of the pan, I noticed some white streaks. These milky white streaks (see picture) are evidence of coolant in the oil, but only a very small amount!!
The question is, how much is too much? Should I be concerned about so little coolant loss and keep running but keep an eye on the amount, or should I lift the head, check the block for cracks etc. etc.? I am aware of the damage the coolant can do if it gets on to the bearings. Note too that I am running with 50:50 antifreeze.
