ROCKET Man,Cap is leaking,replace with stock cap and new gasket,no leaks? quail cap is the culprit.
If I drive over 40mph coolant comes out at the radiator cap. The radiator is new with a qual radiator cap. Any suggestions on how I can fix this!
Sent from my iPad using Tapatalk
I had the same issue, I made mine own gasket with some large rubber washers (you have to cut and play with it until you get a good fit).
Other solutions involve trimming down your water pump vanes (to reduce the quantity) or putting a "flow restrictor" (sold by the parts vendors) in the upper tube, or incorporating a thermostat (sold by the parts vendors.) Any of these will not make a sensible change to your motor temperature as the wide open flow is probably too high anyway. (and the biggest resistance to heat travel is at the copper tube/air juncture at the radiator exterior.)
Joe K
