Converting a 46 Ford coupe.Tried to use a heater motor from NAPA # 655-1020 (61-63 Chevy truck)but about 1/2-3/4 inches too long.
Any suggestions regarding what motor to use or other procedures would be appreciated….thanks
Never changed my 6 volt 2 speed heater motor in my '51 Merc.Converting a 46 Ford coupe.Tried to use a heater motor from NAPA # 655-1020 (61-63 Chevy truck)but about 1/2-3/4 inches too long.
Thanks for the advice, I’m going to reinstall my 6 volt motor.Never changed my 6 volt 2 speed heater motor in my '51 Merc.
Has been running on 12 volts as needed for well over 20 years.
Only difference is it runs faster just like the starter motor.
You are right RB. BTW, that trunk arm fix worked like a charm. RegardsHey pal, you need A/C down there not heater, Happy Easter
Thanks, sounds great…I use one these they work great.
https://vintageautogarage.com/heater-defroster-motor-reducer-12-volt-to-6-volts-100-watts-hr02/
