Dave Covey
1955 Ford car. Has anyone converted to either a Ford AOD or GM 700R4 and used the original column shift?
I'm going with one or the other overdrive trans, leaning 700R4 only because of parts availability.
I want to keep the original shifter. Also want to figure out how or if I can change or modify the shifter gate in the column so the shifter will fall into position as it should for each gear selected. Then I will need to make or buy the plastic gear indicator to match the trans.
Anyone done this or know of anything out there?
Yeah I know I'm weird, but that's how I roll..lol
Thanks
Dave
Thanks
Dave
