Dick M
I have the 30-31 steering box. I need to replace the ball control arm for the advance and throttle. I tried to use a socket and hammer to break the pin that holds the arm in place. No luck. I have also tried to compress the spring to relieve the tension and try to remove the pin with a punch. No luck. I have tried both methods with the steering column out of the car and in the car. Again, no luck.
Any suggestions to remedy my issue would be appreciated.
Thank you..
Thank you..
