I need some other ideas as I am out. My 28 Roadster started running rough above idle. Went through all of the normal checks. I finally decided to check the points gap and then check timing. The issue is that when I put my ohm meter across the points I get continuity whether the points are closed or open. I have checked the lower plate and pigtail, checked that no loose rivets etc.
I am sure that someone else has had this happen. I tried the search but didn't find a thread.
Ideas?
Ideas?
