Connecting the light switch
DerekB
New member
I fixed my horn issue and am now trying to put the light switch back together.
I know the spider goes north and south.
I know the first half goes on the column in only one orientation because of the notch at the bottom.
I know the second half of the housing goes on with harness hole on top, and drain hole on the bottom.
Here’s my problem. I don’t know how to orient the black connector box inside that housing. The housing has a cutout notch, and so does the black plastic part. Nothing seems to protrude to fit in their respective notches. So, I don’t know how it’s supposed to be oriented. The attached photo shows the two “negative” notches. Thanks!
The notch in the contact plate and the lower part of the switch
go in a tab in the upper part of the switch. You can see the tab in the picture right above the bolt.
