Ports here! My new 1930 model A coupe has been delivered from Mass. The car was driven up there before I purchased it. Now that it is at my house I am having trouble getting it to start and idle. Let me explain. I have gone through the start up procedures that I have read and seen on video. Ignition on, emergency brake on, trans in neutral, spark advance all the way up, hand throttle down until gas pedal starts to go down, GAV closed (clockwise) then open about 1/2. If car not started before pull choke out and push starter and let engine crank a few revolutions and then release choke. I believe these are the correct rules for starting a model A.
That being said, the GAV stops when rotated clockwise with the arrow at 9 o.clock. From that position I have been opening it up 1/2 turn which would place it in the 3 o'clock position. Does that sound right? I have noticed that the hand throttle seems to fight me when I try to pull it down. I know it should only be down enough to engage the actual gas pedal but I thought it should be free to move down the entire length freely. Also, how far should the actual gas pedal be up from the floor when not being pushed? As I pull down on the hand throttle, it feels like it is pushing back up. Hope I explained that clearly.
Secondly, I lifted up the right side of hood and noticed that there was some sediment in the sediment bowl that I had not seen when initially looking at the car. I thought maybe some came loose from the trip from Mass to Pa. I will drain the sediment bowl and clean out but first wanted to order some new gaskets before I do that. I also thought I would drain out the gas and put ethanol free gas in the tank. I will check the tank after it is emptied. Is there anything else you may suggest to me before I attempt to get it running.? ( It appears that it wants to start but neighbor said it smelled a little rich when I tried to start it) Anything have to be done with the gas shut off valve?
Someone told me that when I start I should pull the hand throttle up and down a number of times but to me that seems incorrect as all you would be doing is putting too much gas into carb.( pretty sure it is a zenith carb)
The car was owned for over 40 years by a master Model A mechanic who treated it like a family member. He got sick and passed two years ago. The car sat for that period until a friend sold it to me for the owner.s daughter. As I said when it was driven, it drove great.
I don't know if the gentleman who transported it fouled something up when starting it to get it off the trailer to get at another car he was transporting. I believed the gentleman who sold me the car explained to the transporter how to start although he was the one who said to move the hand throttle several times up and down while trying to start the car. Just a thought.
I apologize for this being so long but I am frustrated that it is now not working properly. I have the Les Andrews book and have been reading them. I live in Pottsville, Pa. and am trying to find someone who might have knowledge to help me out. I know how knowledgeable and helpful all of you are on this site and for newbies like me that is great. I know that it is something that can be corrected and it will be soon that I will have it titled, registered and out on the road. Thank you for your help. Ports
