Conduit Clip at Firewall
Hunter
Does someone have an image of the clip that is used to hold the metal wiring conduit to the firewall.
I noticed the reproduction clips have "two legs" that the conduit snaps in between. I have had I think to be a couple of original clips and these do not have the two legs but have a C shape that simply goes over conduit.
Which is correct?
The one with "two legs" (A-14576: Terminal box to generator conduit clip--upper)...it is a special clip unlike the ones that holds the speedometer cable to the fire wall AND the one (A14577:Terminal box to generator conduit clip--lower) that attaches the metal conduit to the A-8275 Cylinder Water Inlet Connection. These two are the same for 28-29 early 30 BUT somewhat different for mid 30-31 (I think) Sorry...no photo.
Pluck
OK, ignore the modern plugs:eek:! Trying to show the '2 leg' clip for Hunter ...
