Kahuna Well-known member Aug 15, 2010 #1 When switching from 6 to 12 volts, is it necessary to change the condensor on the distributor? Thanks Jim
Pete BANNED Aug 15, 2010 #2 Kahuna said: When switching from 6 to 12 volts, is it necessary to change the condensor on the distributor? Thanks Jim Click to expand... It helps if you have a condensor matched to the coil you use. The original will work but you may have some sparking at the points.
Kahuna Well-known member Aug 16, 2010 #4 Thanks, Pete. Yes, Lou, as soon as I get it broken in, I'll do the conversion. Jim
