My repro cable went bad, I want the skinny screw in ignition cable and it's out of stock, so I just took a piece of wire and put a terminal end on it and screwed it to the condensor. I lost the screw and washer in the process, and now I have an allen screw holding it on with no washer. The allen SHCS makes it super easy to install and I've had no problems. You can get away without it.
