Condenser
Gunmetal blue2
Do you guy and gal use the same condenser on your 6 volt system that you use on your 12 volt system? All comments I will say Thank You.
Yes. The capacitor is matched to the inductance of the coil. This permits a sharp fall in coil current creating the spark and also balances the transfer of metal from one side of the points to the other, preventing uneven wear. The pairing is not voltage dependant.
Yes, I mostly use the original style A&L short proof condenser on both my 6 and 12 volt applications. This one is 12 volt and you can see the condenser.
