skip
So let's say the churn shuts off a bit when your driving merrily down the road, then fires up and runs. The car does this a few times before shutting off for good and you had to walk home for the tow strap and a second driver.
You have clean filtered non-watered fuel
You have compression
You have [had] timing, [EZ Starting] good running.
Now, DOA, you have no spark when the points are energized with the key on 'ON' and opened and closed manually. Thinking 'Condenser' on a modern upper plate fitted with 1970 Ford V-8 points and condenser that the condenser might be going to ground.
So I need to poke around with a test light.
Q. Can I run her for a few minutes with the condenser out of the system? Sure, why not? Probably got wet in the drizzle and car washing after the parade.
As cheap as they are, I guess it's over to NAPA. Thanx Tom.
skip.
skip.
