FrankWest Well-known member Jun 29, 2024 #1 my engine stopped again after 30 min, checked condenser Temp at 85 deg C.. Too high?
C Charlie Stephens Well-known member Jun 29, 2024 #2 If it is a V8 do you have a resister in the circuit? The 4's didn't use them. Charie Stephens
FrankWest Well-known member Jun 29, 2024 #3 Charlie Stephens said: If it is a V8 do you have a resister in the circuit? The 4's didn't use them. Charie Stephens Click to expand... Thanks Charlie
drolston Well-known member Jun 29, 2024 #4 FrankWest said: my engine stopped again after 30 min, checked condenser Temp at 85 deg C.. Too high? Click to expand... I presume it would not restart right away. If so, try spraying it with some circuit board Freeze Spray to cool it down and see if it will then start. Or a handkerchief wrapped around some ice cubes for a few minutes,
