Try Renner's Corner.
You are right, they look terrible. I have even considered selling my vehicle because it's "ugly". Maybe I should put a small block Chevy in? Having said that if you can't find the correct condenser get the best Model A condenser you can buy (probably the high end one from Bratton's). Make a pig tail to go from the condenser to the distributer. Elongate the slot in the strap at the end of the condenser slightly and install it. See the attached photos of mine.Many condensers can work on a model b ford it just won't look right.
Charlie Stephens
Here is a photo of my existing condenser and mounting. I don't know if it is the proper original configuration?
Yours is located as original.
I believe this is what you want B-12300, 0.20 to 0.25 mfd about the same rating as the 46-48 6 Cyl condenser which may be offered by NAPA, but it would not have the mounting bracket.
