I'd like to recoat my garage and shop concrete floor with sealer. The surface is worn after about 30 years in spots and it needs to be refreshed from a cosmetic standpoint. There are no or oil spots grease or other stains on the floor.
I've considered epoxy but the need to grind off or to mechanically abraid the sealer seems to be a problem. Even the professionals at $3-5 per square foot won't guarantee their epoxy job epoxy not to peel, delaminate or fail.
So the question is: Has anyone top coated a sealed concrete floor with some wear? What preparation did you do? What did you or would you use? What the original sealer on the floor is unknown since I bought the house from the second owner.
Thanks!
Thanks!
