I doubt that there is any kind of reliable formula or chart to determine this. For one thing, cranking compression will be less than running compression, because at slow cranking speeds compression has more time to bleed down. If you have a somewhat leaky valve or worn rings and hand crank slowly, you will have zero compression. Now hook up a 12 volt battery, and you may have 10-20# compression. With the engine running, maybe 30-40# compression. Plus, while running oil is being splashed on the cylinder walls, which may help the rings seal a little more and raise compression a little. All these results will vary depending on engine temperature and wear, carbon build-up, oil viscosity, etc.
