Compression tester
Most of the suppliers sell a spark plug adapter so you can run modern 14mm plugs. This will let you run a compression test using a standard 14mm fitting. Snyder's part# is A-12405-ADP $6.75. It's what I use.
Has anyone made an adapter to check compressor on cylinders that fit in spark plug hole
Yes, using old plug bust off porcelain JB Weld together or purchase from vendors.
I busted the porcelain insulator out BUT did not have to JB weld in a adapter because my compression gauge has a large rubber tip that fits the opening and I just press the gauge into the hole and take a reading. 👍 😷
I busted porcelain out of an old plug and then threaded the hole with pipe thread tap and adapted to gauge thread.
Older plugs come in 2 parts great for compression check or welding an eyebolt for engine removal.
