bobsmanstuff
If your going to do a compression test on a flathead is it best to remove all plugs before testing?
remove all plugs, open throttle all the way. attach a vacuum gauge to intake and make sure there is NO gas going to carb
What is the reason for the vacuum gauge? I have never used one. I would have thought, seeing that the throttle is wide open, the vacuum gauge would read zero.
The engine cranks faster with all the plugs out, but maybe not an issue?
