BILL WILLIAMSON
Compression test: Make sure the battery's FULLY charged. I give them at least 10 strokes or 'til the gauge no longer rises.
Re-check LOW ones, sometimes carbon gets dis-lodged when removing plugs & gets stuck under a valve.
A leak down tester is BEST! They give you the "REST OF THE STORY"--
Mitch//pa was ALWAYS HARPING about ALWAYS use a Leak Down Tester!!!--WHAR is HE???
Mitchs' KDad
A TIP: When checking valve clearances, check them BEFORE removing the plugs, in case some carbon gets dislodged & gets under the valve face.
Mitchs' KDad
