I think 10 percent between cylinders is ok. But in your case it means very little. You need to put some miles and time on it. Before you check it. Then check it hot after a drive with the throttle held wide open. But if it is running ok and it is not missing why worry about it.
Yes, Dodge,Numbers can vary between gauges also. I have seen up to a 10lb. difference between
gauges. The important thing is difference between cylinders.
