And the compression on a stock engine is low enough not to push the gauge out of the hole as you crank the engine.You can also find an older gauge that uses a one size fits all rubber stopper instead of the screw in type.
thats what i use works goodYou can also find an older gauge that uses a one size fits all rubber stopper instead of the screw in type.
OK I checked out Brattons they sell the adapter but you have to buy a set of four for 24-25 dollars. Should I buy four, I was thinking only needing one ? Would any body know if this plug adapter is a thing that NAPA or other regular auto parts places would sell ?![]()
I would have never thought to hold open the throttle.
