armchair67
I tried searching a bit, but did not find quite the answer to my problem. Two nights ago, my daily driven Model A started making an odd noise, seemingly coming from the engine at somewhat low rpm under load. I have continued to drive the car back and forth to work the past couple of days, still running pretty good but just a little bit less smooth running. Tonight, I pulled the recently installed plugs and found them to be pretty sooty. I did a compression test-the front two cylinders showed 59 and 59 psi respectively. The rear two showed 22-25, which is obviously not a good thing. I have ordered up a touring engine since I plan to put a whole bunch of miles on this car but in), the meantime( the next month and a half to two months, I have a choice-pull the head and see what the story is, or try to milk this thing along and hope it stays together. I put about 1,000 miles a month on this car-any thoughts?
