Keith True
What kind of compression should I be looking for in a 23 T? I've always used the old Ford handbook to work on these with,but I've never found a compression value.I have one with 25 pounds across the board.Low? normal? Is it even important as long as it is even and has some? # one is a little off,not quite a skip,but if shorted to ground when running there is a change but not as much as when the others are shorted.All the coils were sent out and redone years ago,but not used until recently.Swapping them around doesn't change anything so that kind of eliminates them.I'm leaning toward a valve hanging up,too tight,or something in the seat so it leaks at idle.I checked the compression like I was shown as a kid.Take out a plug,start it up,and jam the tester in the hole.Comes up to 25 instantly.
