Chris in WNC
- City
- Jacksonville
- State
- FL
- Price
- $200 firm
COMPLETE multi-disc clutch setup, including 1 flyheel, 2 clutches, 2 clutch housings, 1 set of pedals, 2 transmissions, 1 U-joint and 1 u-joint housing with the dog bones on the side for the early 28 brake cross shaft. Teeth on the flywheel and one set of clutch discs have little to no wear, gears inside one transmission look like NEW. 2nd transmission/clutch is buried under some other parts, so I have not looked inside it yet. I can send photos if you like but have not taken any yet. This will be pricey to ship, but I will crate it for cost of materials if you desire. Or you may pick up at our home in Jacksonville FL or at the MARC Winter Meeting in St. Augustine.
