Complete 351C
TK in LA
La Verne
Ca.
Price
3000
Completely rebuilt 1970/1971 2 bolt main Ford 351C . 0 Miles! Fresh valve job on 2 barrel heads. Erson M/P2 hyd. cam and lifters. Adjustable Push-rods. New Lunati true roller timing chain and gears. New high volume Mellings oil pump with hardened drive shaft. Polished 10/10 crank. All reciprocating assembly parts balanced. New Perfect Circle rings on .030 over TRW pistons. New Cleveite 77 HiPo rod and main bearings. New Ford Cam bearings. New Ford Valley Pan. New Fel-Pro gasket set. Lakewood scatter shield. Good clutch and pressure plate. Polished, open plenum Edelbrock intake manifold with re-built Holley 780cfm dual feed, vacuum secondary carb. New fuel pump. New water pump. New thermostat and housing, New Auto-lite plugs. New Cap and Rotor. Accel Blaster Coil. New Weiand aluminum valve covers. Come hear it run or e-mail for a short clip of it running. Delivery Available for a fee! Stand not included
$3000 obo Ready to drop in and go.
