Vicky
My Transmission shifts fine through all gears and there is no noise in any gear. Sometimes when crusing on the highway, it will slip out of Third Gear. It happens when crusing, not accleration or deaccleration. Also, when you deacclerate in third gear, the shift lever moves slightly back (down), as if being pulled further into gear. I know it probably could be many things, but it seems to me like a shift tower problem. Is there a way to adjust the forks on the Shift Tower? Keeping in mind that Neutral movement is okay and everything else works fine. Thanks for any help. Bob
