While this may be true, it is not what Ford claims! Their claim was because of the benefits of running the engine at a higher temperature.
Where is that printed? I would like to read it. G.M.
When all the systems, steering, brakes etc are in top notch shape 55 is a safe speed. Keep in mind the old brakes are less efficient then new ones which self energize. I myself have a 40 wagon and keep those things in mind while driving by leaving extra room to stop. The wagons I believe are heavier then other passenger cars.
What would you use to clean out the tubes,small wire brush or some thing
Lawrie
I wouldn't be so sure the radiator is plugged. There is a BIG restriction
in ALL old Ford radiators. There are 144 tubes in most of the old
radiators. These are about two feet long and have a small layer of
dirt on all sides inside the tubes. Also if you add the inside area of
the two top hoses dumping water in the radiator it's as I remember
4.5 square inches, add the area of the 144 tubes and it 3.5 square
inches. This is like putting 3 lbs of whatever into a 2 lb bag. The
coolant don't free flow through the radiator, it has to be forced
through. The restriction causes coolant to back up in the top tank
and out the over flow tube. I don't think Ford added a 4 lb pressure
cap to raise the boiling point, it was added to keep the coolant from
going out the overflow. G.M.
