Alaska Jim
As many of you know, I have been working on my '51 Merc. off and on all winter. My question now is, Is there an alignment hole somewhere on the column under the hood to line up the 2 shift arms , while the shift rods are adjusted to fit the shift arms on the trans. ? The trans, and the trans shift arms are not the one's that were originally in the car, and I feel that they are off a bit, especially when shifting into 1st gear. It does not want to always go into first. I have only run the car on jack stands, so this may not be a problem when actually driving the car. I am aware that sometimes, you have to go into 2nd or reverse to get into 1st gear. just the nature of the beast if the car is not moving. any advise/ help is appreciated.--- Jim
