Lamar Wadsworth
Another issue on Ozelle the '55 Ford. Column shift linkage is frozen up, worked fine the last time the car was driven in the late '80s. It will do second to high, but level will not pull back to do reverse and low. Replaced the bushings in the shifter arms where the linkage rods connect. I'm thinking the grease has gotten hard in the housing at the bottom to the column where the shifter arms are. Has anybody else run into that problem? The manual gives an exploded diagram of the mechanism that lets you choose the low-reverse arm or the second-high arm, but doesn't show how to take it apart and put it back together.
