On the column change linkages, the little rubber bush with the brass insert. When fitting new rubbers and bushes, how do you flare (for want of better road) swedge maybe, the new brass insert into the rubber? I've heard they crack or split real easy. I've seen brass rivets set with a spinning tool. Kind of put a flaring cone in a drill press, set it spinning fairly fast, and push down on the press. Same idea work on the column Change bush?
Thanks,
Martin.
Thanks,
Martin.
