blucar
I had a '73 GMC 5500 series in my business for many years, it was a 400 CID V8 w/Clark 5 spd and an Eaton 2 spd rear end. The truck was rated to carry 18K on the rear axle, with a GVW of 30K
The GMC had very similar shift controls as the Columbia under my Ford, only difference was there was no vacuum, everything was electric with solenoids and a small electric servo motor mounted on the axle housing and a control switch mounted to the gear shift stick.
The ratio of the odometer was controlled by a Steward-Warner unit that was very similar to the SW switch in my Columbia control system.
The truck was generally driven as a ten speed, split shifting each gear with the two speed rear axle.
I did the same thing with my '36 when I was street racing.
As a side-bar: During 1954-56 I had a friend that had a '36 5 win coupe that was a Standard car, a real Plain Jane, Dicks car weighed under 2,900 lbs., when we weighed our two cars. The only modifications Dick had done to his coupe was a stock 24 stud engine, hydraulic brakes, 650x16 rear tires and 5 on 5.5 wheels w/47-48 hub caps.
