Columbia question
The axle housing is the hard part. You could use a 37-41 housing by adding the bracket for the radius rod and cutting off the spring hanger. 35-41 is the same width.
34fordy, yes you could drop a 37-41 in if you changed the radius rods and drive shaft too from a 37 on.
What controls do you have to shift from low to high?
I didn't like the look of mounting the control valve on the cylinder head of my flatty. On my 32, I mounted a 36-37 vacuum control on passenger side of the K member, drilled and tapped the clutch cross shaft to attach a lever rod to activate the main valve. Made a custom cable for the hi/lo shift. Works great and you don't see the control valve. Maybe you could do the same. I also have an original electric control set up that I am not going to use, if you decide to go that way.Whatever you do, you want to make sure there's a way to disable the valve if the clutch is not engaged. This way you will not accidentally damage the unit.
I made mine a manual shift like the Ruxtel in model T's
I didn't care for it either, I made a bracket to mount the vacuum switch just in front of my steering box, welded a tab to the clutch arm and then fabricated up some 1/4" OD rod; threaded both ends for a clevis one end and the other a connection to the switch. It works super. Love the Columbia!
cas3
Good job making that work. I was highly considering the manual shift like you did, but it just wasn't coming together. Yours looks great.
Hey Clayton, Does your system eliminate all other controls? Is everything accomplished, in and out with the one lever aside your emergency brake lever? Looks like a great job!!!!!!
Yes, its all done with the hand shift lever. Bad news is you don't get the speedometer correction. I thought it may take some learning to shift it, but no, it shifts just fine like any synchronized transmission.
And yes Denny, poor spelling! I've had 2 of the model T units over the years and should know better!
It's not a problem at all (and I didn't mean any disrespect); it's just that i am constantly amazed at the knowledge (both general and specific) possessed by the members here.
Not a problem here either, just admitting my mistake, and poking you back a little!
Happy motoring.
