With cannister off, the lever from the gears should be toward left or passenger side for standard gear ratio, correct? Presently positioned far right toward drivers side,center of car. Moving this lever manually with car sitting damage gears?? Had cannister off to lube and see lever is pointing toward center of car, think this is overdrive position?
Thanks!!
Thanks!!
