columbia 2 speed
I installed a mitchel in my forty coupe and the only MOD was a hole in the transmission cover. It was easy. Now, you do have minimal clearance between the floor pans and shift linkage compared to a Model A. I installed it without modifications. In my opinion you do not have MAJOR modifications. It cost less than a columbia and well built. I have the 36% reduction with 3.78.
have had 4 cars w/columbia's ,have been unhappy w/3.78 gears and a hot cam, not enough rpm's to let cam work when in od. car i have now ,stock 53 merk eng w/ hi com heads,26 tooth trans gears , 4.44[ v-8 60] gears ,700-16 tires,runs good and can poke around town and not buck and jerk . have one for next car w/4.11 gears, reg trans gears and 9 oo/16 tires. got my controls from mc master carr cat.
Pretty simple to mount the speedo mech on the inside of the firewall. Mine is mounted on the vertical portion of the firewall just behind the cowl vent. the actual mounting only required the drilling of two holes from the engine side to accommodate the two 8-32 screws (longer of course) that originally held the unit to the Columbia head mounting bracket. Relocate the existing speedo cable to the the SW unit and routed a short cable to the odometer. I fed the 1/8"vacuum hoses through an existing grommet in the firewall. The SW unit is clearly visible up behind the cowl vent.
Of course when I did this modification I was in my early twenty's and as we should all remember, doing things the "HARD WAY, STANDING IN A HAMMOCK" was no problem.
i sold mine from my 38 for 2500 bucks and i sold it on this site,first guy that called bought it from virginia
