mgm60
Installing a Columbia 2 Speed in my 36 which has dual Stromberg 97s. Have the carb adapter plate with vacuum port but what do I do with the second carb to keep them at the same height? Use a spacer or use a second adapter plate? If I use a second adapter plate should I just block the vacuum port or plumb it inline with the first? Not a lot of room between the two carbs on my Sharp intake to be able to connect the second vacuum port if its needed.
