Thanks everyone. I did take the vacuum chamber apart, the seal was good, I checked the vacuum, 15 inches on both lines. Then I noticed a crack in the axle housing, I looked closer and it was completely broken on both sides. When we assembled the complete rear axle, the radius arm on the Columbia side was off by half an inch or so to line up with were it bolted to the drive shaft. After some work, we did get the bolt through. Well, that put to much tension on the housing. Fortunately Berie had an extra housing, so it is at the machine shop getting the bearing surface resleaved. Taking it apart and reassembling it will be next month's project.
