Cold weather coming
Tom maxwell
My question is simple....
Extreme cold coming and I'm protected to -10 on the antifreeze engine and radi ator.
To play it safe, I opened the petcock on the low radiator tube to hose.
Drained all the fluid that would come out.
Is this enough to protect the engine. The reason I did this is because in the cars current location, I can't run the engine.
I believe I'm ok temperature wise, but I was wondering if there are areas in the engine that will not drain.
No heat in the garage.
Tom
You are probably fine. As others have said poke a small piece of wire up throgh the hole in the drain **** just to make sure rust hasn't plugged it up leaving a bit of water in there.
Question for Brent, what did you mean by (Remember your battery too.) ???? A battery will only freeze if its dead, and if its dead very long, cold or not, its junk anyway. Just wondered what I'm missing...
Even if you didn't get it all out, and by chance you did get some freezing, there aren't any passages completely full that expansion would cause a problem.
